I'm not worthy
:bow: I'll quote you :
"So when the gauge is in one position it will step to the next once it reaches the set point. If you were to watch the gauge on a dyno (so we can watch the gauge and not the road) as we have you would see it sits still then all at once move to the next point. "
I have no reason to disagree with what you say you have seen, but I have never seen this behavior. stepwise fashion as you are describing. Like a quarts second hand is what I am hearing. I have never seen anything except steady fluid movement
I am just trying to learn something here.:Thumbup: Poking at me with what you perceive is lack of expertise is waste of my time. :itsdeadAll this testing "you have done" and no controverting data to dispute my claim? If you think my chart is wrong, then post what you have and lets compare them. Prove me wrong, if you think thats productive, but give something we can learn from.:hug:
:bounce :bounce :bounce :bounce :bounce :bounce
BTW, my chart was never meant to be a precise claim. It wasn't created under lab conditions, it was done to get a handle on ballpark trustworthiness of an imprecise analog gauge. As anyone can see it has a large range. The "205" you keep picking at, is an estimated analog gauge needle position. Mark calls his 203, whatever. Knock yourself out. It is good to 5 degrees at the most with head movement and parallax error alone. Do I care? No. The needle width alone is 3 degrees, and....I don't care. On an analog, I care about 20 degrees disparities. I don't care if the 12 oclock (210) position represents actual 215 degrees, or 205, or 208. I supplied a range that you will see on this vehicle. And it is "accurate" for what it is! I posted it because I think a lot of people would get use of the fact that a "160" reading, is actually only 110 in the motor. A 50 degree disparity! That is the worst part of THIS gauge IMO. Maybe yours is different. In fact the the first 2 tick marks represent an actual temperature range that is triple the 6 degrees suggested by gauge graduations. That is why it moves so slow at first, and then quickly as it approaches 210. But at around 210, it is a fairly accurate representation IMO.
I can't address your scale question, I don't know the answer, from something archived a year ago. but if you think my data is wrong, say so, but PLEASE have something in its place to claim. No drama. Prove me wrong. I'm wrong all the time.:damnit
