Obviously Intuitive !
Haven't verified it but found this in their online manual @
www.ford.com
might be on the new Superduty as well !
i wont believe it till i see it with my own eyes.....
get under your ex and look!
TDG Mafia Member #24
:agreed:
This is probably yet another case of when the book leads you a million miles from the fix. Perfect example is when you are doing the pinpoint tests and it says Measure resistance on a wire. Is resistance greater or less than 10K ohms. Less then tells you to fix the open and greater than says to put a PCM in it. And you think ummm if the wire has the correct resistance then why does it tell me to fix the open?
I'm gonna go check my 05 for it
So anyone check this?
