Thats awesome Jon!!
Thats a big step!
Thats a big step!
the motor does not fit all that easy, the chain the the top cowling will fight you like hell, when i finally decided to lift the cab it literally fell into place whith little effort. i am sure it can be done like others stated, but it is much easier to just lift the cab slightly.I'll be starting my 6.0 to 12v swap next weekend hopefully. What is the reason for lifting the cab? I thought you could remove and install without raising the cab at all. Looks like you are replacing the 7.3 with a 24v, so it shouldn't be much different than mine. Was it just to clear the crossmember with the oilpan? I'm not planning on raising my cab if I can get away with it. Let me know what you ran into as I'm doing mine by myself also. Steven.
LOL Steel!Jeez... amatuers! lol Should be no cab lifting! Thought I had taught you that Jon! lol jk jk Looks like it's coming along well!
i would like to add that even though you are correct that he did not set the motor back far enuff to use the factory fan and that makes a difference as well... i thought it was rather easy to lift the cab a few incheseyou dont need to raise the cab to do the swap. JPcustoms has a thread about his 6.0 to 12v swap.
no i did not do that, but makes good sense.... bad thing is i am not taking the tranny out again:bang for a while.... my whole project got put on hold my wife is in the hospital with pregnancy issues....:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bang:bangYou having your tq converter stall lowered Jon?
Reason I axe is I have the same converter you do via BTS. I talked with Brian about a month ago and he said the Cummins motors really like the lower stall speed.. I sent mine back to him to have it changed.. Hopefully be getting it back in the next week or two.
Here's mine in its current state (I'm using an early 2004 CR Motor):
