Thuren
2003/2006 Dodge track bar
INSTALL
2004 Dodge Ram 2500 HD 4x4
Cummins TurboDiesel
* Fits 2003 - 2006 Dodge Ram 2500-3500 4x4 trucks
* Made from .25" wall DOM steel
* Mandrel bent
* Heavy duty shank chromoly heim at axle
* Proven poly/nylon hybrid bushing at frame
* Provides much improved steering feel
* Improved suspension feel
* Easy bolt in replacement
* Shipped bare steel. Requires painting
* May require MINOR trimming to aftermarket frame brackets...
Visit Thuren Fabrication here for more info.
DISCLAIMER
This install article is only for reference. Do not use it as directions
to install your kit.
The bar arrives unpainted so...
This is a series of pictures with little or no text. Basically two bolts are removed.
No jack needed. When Installing the new bar have someone turn the steering to line up the second bolt hole.
I adjusted the link to be slightly make the new bar slightly longer than stock to accomidate the 2" leveling springs.
Stainless bushings are supplied with the bar.
