1 - 11 of 11 Posts
SRW Cartell #27
I had to change my oil yesterday (My normal 3000 mile change) and noticed that it was thin and about a quart high. I think i may have some injector leakage. :shrug: I am going to watch it real close and see if it does it again. I cannot smell diesel in the oil . I put a drip of oil for the paper test and it has a halo but it is a small one which was normal for the truck .:deal: I looked at my make date and my injector warrenty ends in a month or so ... 7yrs. I am hoping that it is not injector problems. I hope i just over filled it when i changed it last time. :shrug: We will see.
Nasty Girl
Unfortunately I would say you have an injector problem. :damnit I would take a sample and have it tested or take her in and have your local stealer test ASAP.
SRW Cartell #27
I had the injectors tested about a year ago because i thought one was leaking my oil thins out fast with in 3-4000 miles then my oil pressure starts dropping. They told me that the leak was not bad enough because it is not showing up in a pressure test.
F
Sounds to me like you assumption is correct, everyone knows the LB7 injectors are known for this. I think a trip to the dealer may pay off in the end.
SRW Cartell #27
I guess i better get it in then ... Bummer ... Do i need to take the stacks off for a dealer trip and run my factory exaust? Also should i take the lift pump out?
SRW Cartell #27
Thanks Guys.
Stacks wouldnt have any effect on the injectors. I WOULD remove any programming and/or tuner from the truck.
It does sound like the injectors are starting to head south. Not bad enough to cause poor performance, though. It may be tough to convince a dealer they need replacing. Good Luck.
TDG Junior Mafia #61
I would go have the injectors replaced anyway, because last time we had ours replaced they said it would be $1600 with no warranty, so get them replaced when you can.
I have a stupid question, does GM replace them with different/better injectors? Or should you just bite it and purchase different ones?
SRW Cartell #27
Good question. Does anyone have this answer. If the dealer wont replace them then can someone tell me the procedure on how to replace them . and how much of a pain it is to get them out. I may just replace them my self if the dealer wont.
Nasty Girl
GM replaces with their 4th gen injector IIRC.
1 - 11 of 11 Posts
