my tractor has 275/80R22.5 tires on it, I am in a pinch can I use a 295/75R22.5 on it mixed with the 275's? can I run 275's on one axle and 295's on the other axle? or even 275's on one side of the same axle and 295's on the other side of the same axle?? I have been told they are the same size height wise. I am talking used tires here. thanks in advance...
I was always told buy the tire guys that thay are the same size and will work with each other allthow i have my debouts i have put them togather with no problems in the past.
Running the numbers the 295/75 is 39.92" tall and the 275/80 is 39.82" tall, only 0.10" difference. I would think as long as you are not locking the axles you would be "ok" either way.
