I was doing a little homework & comparison between the 2010 F-450 DRW and the new 2011. We all know the difference in the wheel size (from 19.5" down to 17"), but I was surprised to see a change in tire width as well? Based on the specs I have, the '11 will have 245/75R17 tires whereas the '10 has 225/70R19.5.
If this is correct, it would indicate that the '11 has a tire width of 9.64" whereas the '10 has a width of 8.86". Moreover, the overall height of each wheel/tire on the '11 is 36.3" whereas height on the '10 is 37.2". So the 2011 wheels/tires are just about an inch shorter overall, but almost an inch wider. Can someone confirm?
Apparently the 1" smaller diameter offers better gas mileage (from what I'm reading), but will it also result in any ride/traction degradation? In other words, aside from looks, what's the downside of the new tire/wheel configuration?
Also, the options indicate both all-season and all-terrain versions of the tires. Do the latter really offer tremendous advantages in traction, particularly in snow?
