If the box of your truck is the hell for perfectionist, then it is right time for considering about the tool box. Whether working on a project in the garage, or traveling to different jobs throughout the day, a tool box will keep the equipment safe and well-organized. Choosing the ideal tool storage box can make all of the difference when it comes to securing the equipment and enjoying greater ease of access.
There are several different tool box designs that are growing in popularity by the day. They are custom designed for truck models and specific purposes. So we made a selection of some great tool boxes for you. Let's take a look at the various ways you can store tools in your truck bed.
Dee Zee® - Red Label Tool Box
http://www.carid.com/dee-zee/red-label-tool-box.html
* Gas shocks allow lids to glide open or closed smoothly;
* Boxes are available in multiple sizes for both full-size and smaller pickups;
* Limited lifetime manufacturer warranty on aluminum, 1-year warranty on outer finish;
* Proudly manufactured in the United States;
Dee Zee® - Blue Label Diamond-Tread Utility Chest Tool Box
http://www.carid.com/dee-zee/blue-label-utility-chest-tool-box.html
* A full-length hinge on all boxes prevents uneven opening and is concealed to prevent contact or jamming against items inside;
* Rubber gasket seals keep moisture and the elements out;
Dee Zee® - Triangle Tool Box
http://www.carid.com/dee-zee/triangle-tool-box.html
* Available in multiple sizes;
* Designed with a shape to match the triangular narrowing beams at the front of your trailer;
* Crafted of durable standard Dee Zee thickness .056 aluminum;
Dee Zee® - Wheel Well Tool Box
http://www.carid.com/dee-zee/wheel-well-tool-box.html
* Available in sizes that offer storage on top of and behind wheel well humps, or in double-wide size for storage on both sides of the wheel hump;
* Versions are available with slide-out drawers;
TruXedo® - TonneauMate Toolbox
http://www.carid.com/truxedo-bed-accessories/truxedo-bed-accessories-335226.html
Fitment Notes: The item is not compatible with track system.
* Completely universal toolbox;
* Mounts under tonneau cover for added security;
* Measurements: 55" long, 22" wide and 15" high;
Check out this article it will help you to define what type of truck bed tool box you need:
http://www.carid.com/articles/types-of-truck-bed-tool-boxes.html
Which one is the best for you?
