ok, here goes... i have an 8500lb 5er im towing from north east north carolina to nothern nj, not much in the way as far as hills/grades. i generally use my 80economy tune for daily driving, been meaning to get a tow tune, but i havent really had the money/ wasnt a priority, till i found out im moving the camper next tuesday. i have no pyro. is this going to cause any problems or should i run it on the stock setting. i have as of right now, no start/80e/stock/120race. thanks in advance.
ps- i have diy intake/ 4"straight pipe:thinking
Wow...without the aid of a pyro...I personally wouldn't risk it.
Odds are you would be ok...but lately the odds have been kicking my tail LOL LOL
Reactions: pently
TDG Mafia Member # 37
I towed in my 80e program all the time when I had it and now tow in my 120 race program with my 5th wheel. I have never seen over 1150* F but I had a GTP 38R and now am using a ported ATS shroud, an 1.00 exhaust housing with the Banks wicked wheel. I don't know what you have for a turbo but I guess I wouldn't recommend it without gauges either you just never know. As the old addage says {Better safe than sorry}. Gene
Reactions: pently
Pulling Sled for hire
Do you have an auto or manual? I know that Jody said the 80E has different shift points and everything, and isn't intended to be a tow program especially with an auto but people still use it for that sometimes. It has more timing to help with mileage, so it's not the best tune to "beat" on your truck with.
Justin
The only weight we will recommend towing in the 80E is under 5k. The reason is our 1/2 ,3/4, and 1 ton trucks have good torque stock, but when you go up in load weight you are running the risk of elevating EGT's. This why we have so many tow tunes for so many different load weights.
80 tow or even the 60 tow is what I would get for the 2 types of terrain you will be driving thru. The 80 tow for flat lands and the 60 tow for the rolling hills through PA.
Diane
getting tow soon
i was planning on sending my chip in for some more tunes after i get up there, im moving, so kinda tight on cash at the moment, and i wouldnt have it back by tuesday. the route i was gonna take is 13, right up the coast to the NJpike. only hills i should see are in north jersey. ill just run in stock to be safe. thanks to everyone who took the time to help me out. i love this place.:happymugs
Diane
When I ordered mine and talked to Jody he told me not to worry about getting a 80T for my 8000lb trailer.. he side just use the 80E and go to the 60T if it starts getting hot. now your saying to not use the 80E? if I would have been told this then I would have got a 80T.
Steve
Steve
Factually speaking NO ONE should tow without gauges
If you have gauges and you watch them, but the OP said he doesn't have gauges. I should have specified that.
I just confirmed with Jody, If you have gauges to monitor you can up to 8k. But is it recommended? Not for everyone. Only if you have the newest version of the 80E you can tow lighter weights up to 8k in it.
Remember our trucks have good stock torque anyway up to "X" lbs. If he drove a stock F150 I would say absolutely not. (If he drove an F150 he would not get 80 rwhp anyway out of anything drivable. lol)
