So I hit up Bandimere last night and was a little dissapointed in the results. I posted down in the track forum, but thought I might get better feedback up here.
I know I need to install my Fuelab to fix my fuel pressure issue. But would be interested to know what you guys think...
Sam
are you running stock injectors?
also I was thinking you had an H2E or am I thinking about some one else
if your dose weigh 9700lb's like you said in the other forum that would be like 450rwhp (by the calculator)
it takes a lot of power to move that much weight.
I adjusted my signature... I have hybrids, H2E w/19cm housing, 6.0 IC, a BTS tranny, comp cams, valave springs, p-rods, and Swamps tuning right now... Giant lift gate, big ugly winch bumper, 100gallon fuel tank, and I had about ~50gallons in the truck...
Thats what I was thinking you had for injectors but wasn't sure, and that thing definatly looked heavy when I saw it LOL
what kind of nozzles do your hybrids have. if thet're pretty small you may not to far off hp wise if your get the fuel pressure issue fixed.
it would be interesting to see what it would do at the track if you could loose about 2,000lbs
Shave 2k lbs? Eventually... Would like to get a custom flat bed with larger fuel tank built in. But about the only thing that might come off soon is the bumper. I don't need the winch and would prefer a smaller IronBull type bumper... But then it probably wouldn't look quite like a "trash truck"...
Sam
