1 - 15 of 15 Posts
I have heard that ladder bars are not a good choice for a tow rig. Why is that? If they are indeed a bad choice what form of traction control should I build?
ladder bars alone would be bad as they would cause binding in the suspension. ladder bars with a shackle would be better as they will allow the suspension to still move but will control axle wrap and wheel hop.
fully linked rear? as in remove leaf springs?
No, either a single center link or a set of links on both sides working in conjunction with the leaf springs.
i dont understand. are you talking about a traction bar? that would be a single link.
with the torque and load, i dont think that would be sufficient.
If I went that route it would have been much larger. On a six cylinder trail truck, that was enough. No, I think I have decided on a shackle ladder bar set up instead.
good choice. remember, traction bars are good long. ladder bars are good short.
2-3ft is a good length.
1 - 15 of 15 Posts
