Hi, i have a 93 f250 with a e40d, i recently changed the rpm sensor and tps. When i just start my truck and get going and let off the throtle, the OD button flashes. When i press on the throtle again it goes away and does not come back, only does this when cold and have not given it much time to warm up, like a minute. Could this be because of a bad speed sensor??
Grumpy Old Member
You need to have the ecm scanned for any codes, it may have one stored without iluminating the check engine light. Have you serviced the tranny filter?
Discussion Starter · #3 ·
Yup i did serviced the filter when i changed my fluid a couple months ago, but it only started doing it once i put on a new TPS and goes away when i press down on the throtle.
Grumpy Old Member
OK it sounds like a sensor issue. You need to have it scanned and find what codes are in it. This will get you pointed in the right direction.
