Ford 6.4 it's just cooler
If I rebuild my tranny, is it fine to keep all stock stuff and just do aftermarket converter, clutches, and shafts? Also would I need different tuning for this?
You will be able to run the same tunning as before. I'm not sure if you have a TCM or not, but if you do I've heard that you are supposed to run the Ford direct drive solenoid, not the modified one from suncoast.
yeah I have a spartan tcm, ok good to know. thanks
