I thougth I was having a TPS problem but after replacing it and replacing the shaft bushings It still up and down shifts from 4th to overdrive and back down again?? i put a TC switch on and that stopped it but when I drive around town I can't use the switch because it won't unlock and stalls the truck so I drive without it anybody know? A little help here! Is this a sign of impending doom?
What MPH and RPM does it happen at? 3.55 gears or 4.10s? Loaded or unloaded? If you are sitting right where it wants to shift up or down, it will happen. Try to stay above or below it. The T/V cable might need to be readjusted.
Get mine in the right zone, it will hunt in town. Mostly depends on who I get stuck behind. Normally not an issue.
Discussion Starter · #3 ·
Tell me how to adjust the t/v cable?!
