1 - 13 of 13 Posts
SRW Cartell #27
Question. When i am towing a load from 14000 up. I take off in 1st gear on the allison it feels like it is slipping but i know it is not i want to say it feels like a shuttering viberation. Like the torque converter is jumping. It only happens in first gear.. all other gears i can stand on it and it doesnt care one bit but only taking off in 1st. Is it my torque converter just doing this because it is not at full lock .. or what. It is not the clutches slipping i removed the tranny and no clutches are burned.
Do you guys who pull loads feel this also or is my converter going out..
TDG Junior Mafia #61
I know that feeling, its ok, never stopped us.
SRW Cartell #27
I wasnt sure because it has been doing it since i had the truck but even after the tranny rebuild it still does...
yeah my truck seems like it does that too. even when it is empty and no load, almost like the tires are sorta trying to spin ? it was doing it really bad when i first got it and it just got worse so after tring to firgure it out after a couple of days i found out most of it was comming from the carrier bearing.because of the lift i have on the truck the angle on the rear drive shaft was pretty bad , so i replaced the carrier bearing and put a piece of 1 inch square tube between the bearing housing and where it bolted up and it has helped out alot, but it also have something to do with the rear diff if you have a limted slip locking up.just a few thoughts.
Thats funny, my 93 F-350 was doing the exact same thing. Stomp on it and a weird bounce, but after that i could hammer on it and normal operation. Two different guys said u-joints but i never tried changing them. I am now the proud owner of an 02 duramax and havent had this problem yet but I've only owned it for 2 days:)
I think its normal
SRW Cartell #27
Thanks for all your input that makes me feel better.
'01 of The Originals
launch shudder...you need the 1 piece aluminum telephone pole drive shaft!
SRW Cartell #27
launch shudder you nailed it. So its because of the 2 piece shaft?
To fix the launch shudder actually, we got neoprene bushings or however its spelled, those fixed it.
1 - 13 of 13 Posts
