On my dad's '01 2500 2WD with the NV5600 transmission, his output shaft seal on the back of the transmission keeps poping out of the transmission causing a severe fluid loss. It's happend three times within the last month. Any ideas?
your vent could be plugged, pull it off and blow air threw it. your probably going to have to drop the tranny down to reach it though.
milkin cowboy
Dont starve that tranny for fluid they lock up quick, I always make sure its the right fluid and add extra they need it. Its big money to fix if you can even find the parts now good luck
We are running Amsoils Syncromesh transmission fluid which is recommended by amsoil for a NV5600.
Is the breather tube on an NV5600 able to be taken out of the transmission, to be checked and serviced?
