I tried too hook up a lock-up switch and screwed something up. My truck is running through gears alot fastser than normal. it came up with a few codes. my low beams went out and speedo quit working? i took all the lock-up stuff off and its still doing it.
welcome to the garage.
A little more info on the truck would be nice, if you fill in your signature under user Cp it will help us out a lot.
Was this a switch you bought from a vendor or were you just trying to ground out wire to you lock up clutch. Check all of you wiring harness connectors and pigtails under the hood back by the fire wall. I don't remember what I was installing I think it was my RAD but I knocked one of those a little loose a a bunch of similar stuff happened. Weird shifting, gauges out ect. Good luck and with a little more info we can probably help you get this sorted out.
