1 - 20 of 30 Posts
My buddy has an early 99 F250 4x4 automatic and we put the trans probe for the temp gauge in a test port on the driver's side of the tranny but I think it is too high and is not reading anything no matter how long or what he drives. Is there a lower port or different hole the mount the probe in?
Thanks
David
what's the temperture outside?
when its cold out mine doesnt come off 100 unless im towing heavy
TDG Mafia Member # 37
From my experience that is normal. My truck does not move off 100* either when it's cold out. Even pulling my 24' fully enclosed snowmobile trailer loaded which weighs in around 7500 lbs. I don't see over 115*. It takes mid to high 90's in the summer pulling my fifth wheel to see temps over 170*. Gene :mafia
Do you have the guage grounded properly? The temp probe in my early 99 is in the same spot and is reading just fine.
Tim
so do you guys think that the test port is fine even being kinda high, as on mine its right inline w/ the linkage it seems like and his is higher??
sorry for the confusion, he has one that we know of thats what we are asking i was saying that my probe is in a port that is inline w/ the linkage lower then where his is
Sounds like mine is about the same as yours. On the driver side, in front of the linkage just above the pan. Your buddy's is higher?
Is it a single wire probe? My autometer trans gauge has two grounds, one for light and one for the probe. The two are tied in together along with my other gauges for a single ground. If the probe ground is not grounded properly then it won't show a reading. May just want to double check this.
99powerstroke said:
yep that is where mine is and his is higher in a test port
His early 99 should have the same ports as we do. I guess just move it down assuming his truck has the same ports as the rest of us.
Yeah, the tranny case didn't change for a long time. Plugs are all in the same position.
Discussion Starter #18
well thats the thing mine is a 2wd and his is a 4x4 so i wasnt sure if that is the same tranny or not and he doesnt have the same port as I do that is why we did it up higher w/ his port was...
1 - 20 of 30 Posts
