the truck is throwing codes the codes are p0761 shift selonoid and p02702 friction plate issue symptoms are when the truck is at 20 mph and u get back into it is bangs real hard into gear twice then throws the code any ideas
Mine does that everyonce in awhile as well,try adding a quart of fluid if you never have and that seems to help. other then that another thing is try to wait till you slow down alittle more thenget back on it
added the fluid brand new trans in the truck do to this issue before something dot seem right ford wants it stock and it cant replicate it stock
what tuner are you running? the onlything i can really think is to try getting it updated.
