a friend has an 05 pete 330? with a 8.3 cummins and an eaton fso8406a 6-speed. he's looking to swap the tranny for a rockwell mo13610am which was bolted up to a c-12. Will it bolt up or is there some modification to make it fit?:help
As long as the SAE bellhouseing size thatl fit but your clutch spline size will be diff. almost for shure. Getting the shift tower threw the floor wear you want it may not happen but mabe. If your gonig to go therw all the trouble of swaping in a 10 speed WHY woud you evin think of useing a rockwell/ meritor trans ? ( theres a reasion thay stoped makeing there own trans. ) put in a FULLER
LOOKING TO DO THE SAME BUT WHAT 10 SPEED WILL FIT?
