2002, ran a check and came up with two codes p0201, and p1261. started truck up this mourning ran for about 3 minutes and then started running rough, it was about 10 degrees out, and the fuel was less than a quarter of a tank, changed fuel filter made no difference, checked air filter , the one code came up injector circuit malfunction, p0201, and the other one i couldn't find. hope someone can help THANKS
TDG Mafia # 81
P0201** Injector Circuit Malfunction - Cylinder 1
P1261** Injector Positive Voltage Control Circuit
Took two differant sites to find the two, but there is what these two codes are. Hope this helps you, I have not had any problems with mine yet, and hoping not to, but hopefully you get yours figured out.
Tony
