I was returning truck to stock, I started loading 150hp dpf on tune then started swapping parts over. The dash daq was done with the programming I had the doc/dpf pipe on and stock intake on I turned the key off for ten sec then started truck then I shut it off again but one exhaust sensor was not plugged in. I cont to put the rest of the exhaust on and that is when I noticed the sensor was not plugged in. The motor won,t even turn over and the batteries are good. Any help would be appreciated. It is 08 6.4l
There was a code stating exhaust sensor voltage low I cleared the code and still would not start so I tried changing the programing and set to stock and then it started.
