1 - 10 of 10 Posts
the chevy in my sig is wat im refering to. i have37x12.50 bfg mud terrains.wen the truck isnt rolling i can not turn the wheel. as soon as i touch the gas and get it rolling i can kind of turn it. is this wat i can expect with this tire set up or is there something wrong or sumthing i can do to help. almost got stuck in a parking lot the other day. lol kinda scary thanx.......
You should be able o turn the wheels even stopped. Try the obvious things like power steering fluid and belt tension on the pump.
TDG Mafia Member #82
Setting still i cant turn my 37's Id say thats the problem just let it roll a little and it should straightn right up thats what i have to do........Just always back into parking spots!!
haha yes sir gotta park in the boonies and back in on top of that. yea i guess ill jus hav to live with it cuz everyting is fine with all steering related parts and fluid levels... god love the duramax and alison tho... lol first chevy
GM power steering pumps arent the best. I would be checking to see if the P/S pump shaft broke if the belt is fine and the fluid level is normal.
my first question would be, how are your brakes?
Are they normal, or are they hard to press?
With stock tires, from time to time I will even have a hard time to get the tires to turn. There is a know issue with the use of the brakes and turning while at idle. Chevy claims that everything is fine with the system, and that this is normal.
37's are not that big of tire, check pump, not the belt tension per say because it has a auto tensioner. But the guts inside the pump might have failed. Check fuild, also fluch/bleed refill and see if that helps. Check bumps stops is the last resort, might modify if the hit lock to lock. Also check all other linkages.
Sure theyre not if your crushing cars in big foot but compare them to stock255 or 265 then say that!
:poke:
i think its jus a gm power steering pump thing cuz my old man has an 8 lifted h2 on 37's and the other day i was drivin it and it wouldnt turn jus like my chevy. sooo im not to worried jus kind of annoyed wen i get into tite spots in parking lots and such. wish i bought a shortbed sometimes until i load my dirtbikes and all our gear and easily shut my tailgate. lol lol and 37's are a big tire......
could always get a bigger steering wheel. lol
1 - 10 of 10 Posts
