whats going on everyone.
Today I went to move my 1994 F350 XL Diesel (non turbo) dump. I went to shut it off it wouldnt shut off.TOOK the key out and still running, so I popped the hood and pulled a plug out of the engine..it shut off, then had to pull the wires of the battery to kill the radio and everything else. checked all the Relays, the only thing I think it is,is the ignition,because when the key is in i clicked it wouldnt shut off, but when i took the key out it the key igniton would say the truck is off ,because the ABS LIGHT, and the E brake would be on but the radio would be off! SO I AM THINKING ITS THE IGNITION.
IF ANYONE KNOWS OR THINKS WHAT IT IS I APPRECIATE YOUR HELP.
THANKS
Your ignition switch on the lower end of the steering column may be bad or out of adjustment. Hopefuly you didn't break the actuator in the steering wheel.
