Hey PSD try this one, I looked at the wrong number
1FTJW35F3TEA35480
OASIS RESULT:
1FTJW35F3TEA35480
See bottom of the OASIS result for contact ID
02/02/2006
22:44:04
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1996 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
7.3L TURBO - DI
TRANSMISSION
ZF 5 SPD CLOSE RATIO AXLE CODE
45 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/25/1996 BUILD DATE
11/01/1995 SALE MILEAGE
00355
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
1FTJW35F3TEA35480 T/F1 * T/BC T/CD T/B A1 T/RK T/DS 01-NOV-1995 25-JAN-1996 147599 USA 1 7F01 011600 F4TZ 17526 A W05 02 355
AWS Claim Key: 540703 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01899 - * Name: KERNS FORD-LINCOLN-MERCURY, INC. Ph: 419-3947691 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-1996 Doc #:38577601
Cust Comments: RIGHT WINDSHIELD WIPER BENT
Tech Comments: REPLACED WIPER ARM
1FTJW35F3TEA35480 T/F1 * T/BC T/CD T/B A1 T/RK T/DS 01-NOV-1995 25-JAN-1996 147599 USA 11 2B03 030703 F6TZ 12B533 AA D03 42 17831
AWS Claim Key: 4810825 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07417 - * Name: GRAND FORD, INC. Ph: 330-3866120 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:27-NOV-1996 Doc #:1634301
1FTJW35F3TEA35480 T/F1 * T/BC T/CD T/B A1 T/RK T/DS 01-NOV-1995 25-JAN-1996 147599 USA 33 * * * * * * * 56001
AWS Claim Key: 16408119 Trx Code: 97B16 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07417 - * Name: GRAND FORD, INC. Ph: 330-3866120 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:28-SEP-1998 Doc #:00515001
Cust Comments: INSPECT AIR CLEANER PER 97B16
1FTJW35F3TEA35480 T/F1 * T/BC T/CD T/B A1 T/RK T/DS 01-NOV-1995 25-JAN-1996 147599 USA 46 2B03 030008 F7TZ 12B533 CA D03 46 70460
AWS Claim Key: 19500878 Trx Code: E72 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 02173 - * Name: WILLIAMS MOTOR CO., INC. Ph: 440-2342770 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-1999 Doc #:05648351
Cust Comments: CK FOR HARD STARTING WHEN COLD IN THE A.M. STRONG AND HARD ALSO NOTICE WHIE SMOKE FROM THE TAIL PIPE WHEN CRANKING
Tech Comments: PERFORM HARD START NO START DIAGNOSTICS, SEE ATTACHED SHEET FOR TESTS RUN KOEO P1111, KOER P1111, REAR TANK FUEL PUMP PRESSURE 60 PSI AND FRT TANK FUEL PUMP PRESSURE 60 PSI REPLACE GLOW PLUG RELAY, CONTACTS BURNT NOTE: VEHICLE NEEDS CLUTCH, PRESSURE PLATE, THROW OUT BEARING, SLAVE CYLINDER AND POSSIBLE FLYWHEEL, CUSTOMER ADVISED A
1FTJW35F3TEA35480 T/F1 * T/BC T/CD T/B A1 T/RK T/DS 01-NOV-1995 25-JAN-1996 147599 USA 59 2I04 030008 F7TZ 12B533 CA D03 41 86429
AWS Claim Key: 20299193 Trx Code: E72 Labor Hrs: 3
Dlr Cd-Sub Cd: 02233 - * Name: DUTRO FORD-L/M INC Ph: 740-4526334 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:24-NOV-2000 Doc #:10647501
Cust Comments: ENG CRANKS LONG BEFORE STARTING
Tech Comments: RAN SELF TEST W1TH NGS KOEC KOEO KOEO 1NJECTOR TEST KOER KOERCYL BALLANCE ALL PASSED P1111 RAN CHECK ON GLOW PLUG REPLACED GLOW PLUG CONTRPLER AND 7 GLOW PLUGS DD NOT REPLACE NUMBER 1 GLOW PLUG RERAN SYSTEM CHECK ON GLOW PLUGS ALL
Thankyou very much PSD. I didn't know if it would be too old or not.
I appreciate your help.
Tim
