1 - 18 of 18 Posts
TDG MAFIA MEMBER #71
Which setting do ya put it on to get the best milage? :popcorn:
I would say a 100-120 setting if you can keep your foot out of it...
TDG Mafia - Booze Runner
I would say 80; 100 and 120 are to tempting to not keep your foot out of it:evil:
ts doesnt have a 80 or 120 setting just 50, 75, 100, 140....
They do... You just might not have it on your chip...
I had it on 140 this weekend will traveling and only got 14mpg.
I got my best MPG while in the 80 setting 17 +/- MPG. Try your 75 for a while.... I just watched the fuel gauge laugh while I used the 140 setting, and me smile while I left soot on CSIPSD hood LOL.....
Thanks, I was going to work my way down until I got good milage, It is really hard not to mash it every now and then.........
I run mine on 75 and 100 most of the time..hpop does'nt like 140hp much
Mine seems to get the best mileage in the 75hp setting. Only makes a little bit of black smoke when I get on it...
dfuser said:
The new ones I have has a 185 hp setting! I guess I should ask them about that.....
as it stands now anything over 120, even 100 in some cases is gonna need upgraded oil and probably injectors to get any use out of the programing...IMO
Discussion Starter #13
I can see a difference in all settings.
your truck will run like crap.
My 6 pos chip doesnt even have the 140 setting on it....
the guys at Elite Diesel told me people were running stock trucks on that setting as a smoke file and causing problems.
So cause i knew i would be tempted to use the 140 setting for that reason,,, i had them not put it on.
if i get new injectors or something, im gonna need the chip reburned anyways.... then they can put the 140 setting back on there when the rest of the engine can keep up with it.
Discussion Starter #16
It actually run fine in the 140 setting.........some smoke when I hit the go pedal hard......
I personally run in the 50 tow setting, it isn't too tempting to slam the go pedal, and at 60 mph I can pull 19 mpg
Discussion Starter #18
I am about do to fill up so I will have to try that......
1 - 18 of 18 Posts
