i just got my new chip from ts and the settings i put on it are high idle,75,100,125,140,drag,sled pull. chip works great i have a 1997 f350 with a 5 speed and on the sled pull file the truck runs ruff at idle but when i hit the throttle clears up and power is there with tons of smoke is this normal or not thanks :thanks: :shrug:
anyone have any input on this problem?:thanks:
Dont know what to tell you... On a 97 without injectors and HPO upgrades your wasteing your money with anything more then a 80-100hp setting on the chip... there is just nothing left to give...
I just installed a chip from Tony that acts the same. Answer was that it was normal.
How do you get seven settings out of a six position chip (high idle,75,100,125,140,drag,sled pull) :shrug:
The chip actually had 16 positions on it...but not many use all 16. I think DP will load it up if you want it....
it has 6 my bad no 125 sorry about that:Thumbup: :thanks:
Only Jodys F5 has that ablity... The TS blanks that everyone else uses are a 6 pos only...
