Seeing what the opinions are for this. Ive got a 06 kw with 5.9 260hp. The 15% setting could be useful at 300hp. In general, how are these boxes for the med duty motors. Thanks.
Super Moderator
Generally, you dont see the actual gains they advertise. Also, 260 is quite a bit for a little 5.9 in a heavy truck. Sure you wanna do that to it?
you probably are right, since its my work truck. I just has this annoying trait of not spooling out of a driveway (hill) with a load. A similar test is if i set the parking brake and floor it in drive, it revs to 1500 and smokes. I thought for sure my new turbo was going to let it spool up. I had check engine lights for a while all pertaining to vgt codes. I hoped it was stuck open, so it had trouble spinning up at low rpms. But it didnt change, at least no more cel.
