what is the best tune for my truck? it's a 95 psd reg cab long bed, with a 5 speed, stage two injectors, ts chip, beans dominator 66, inter cooled, modified idm, intake, exhaust, full fass system, stock hpop but new. the local shop put a hot tune on the chip when i got the injectors but the truck will throw the cel when I'm on a good hill at wide open throttle. or just playing around on the hot setting.:thumbdown thanks for any help
The CEL is probably from running out of ICP, especially if you have a 15* HPOP--w/o a pump(s) upgrade, there's not a whole lot you can do to avoid the light unless you lighten up on your right foot.
:whs
wether its new or not, a 15* pump isnt enough for stage 2's... a regular 17* almost isnt enough for stage 2's....
thats your problem...
:stupid
Mafia Member #93
Termintator Engineering... call them.... Joey will set ya up....
big oil is your best bet, dont waste your time with a 17.... and YES, you will see a big gain in your case cause that 15 is no where near enough oil for those stage 2's....
We have two big oil vendors...Stealth and Terminator. Both will do what you need. The Termy is a dual pump setup...the new Stealth is a single setup.
Ask around...and be careful of all the cheerleaders. Both camps have vocal cheerleaders and can be a bit biased. Or...better yet...call both companies and speak to the builders of said pumps.
i think im gonna go with the stealth pump. should i get a stage1 or 2? is the four line kit worth it or not? i thank you all for the help... on making up my mind!!
