Ok, I replaced the transmission throttle valve actuator on a 2006 Ram 3500, with the 48RE transmission. My question is, is it supposed to be under the spring loaded tension when you mount it, or is something stuck? I’ve got the code for the valve being stuck open, and was trying to figure out where to go with it.
