1 - 20 of 32 Posts
I have been trying to compare different brands of replacement compressor wheels. I think most people go with the wicked wheel but, I want info (good or bad) about all brands. All feedback is appreciated.
Thank you,
Kenny
:popcorn:
The compressor wheels you are talking about are nothing more than a OBS/early 99 compressor wheel. The only difference that I have heard of is that the Banks wheels are slightly thicker to hold up to high boost. I don't know much about any of the other brands.
funny you should say thati have ordered the Banks wheel and it came int he same box with the same part # as the one we get from our supplier.... if you want a compressor upgrade we have oen for the 7.3l a real larger compressor wheel
Diesel Mafia #67
a buddy of mine is running the whicked wheel compressor wheel .. dont know much about it tho..
I don't doubt that in the least. A lot of parts seem to be that way these days.
The wicked wheel maker claims that it will reduse or eliminate turbo surge, how much truth is there to it? or with any other brands?:shrug:
TDG Mafia Member # 70
TDG MAFIA MEMBER #77
I installed the WW in my 99.5. It has reduced surge / stall maybe 15%. It whistles much more than the stock wheel did though. If you are still running the stock air box, the reduction is surge is much higher.
It completely eliminated the surge in my truck...
Good luck,
Steven
gtspowerstroke said:
Wow that's scarey that a shop that actually sells parts is telling people to stick a screwdriver in the turbine to break the compressor wheel loose!!!!:eek:
Sorry Geoff... We all dont do it your way:squish :poke: LOL ...
I have installed many that way and never had an issue... but I didnt get them rebalanced eather:pointlaugh !!! OMG!!! I am going to blow up from a turbo thats not balanced...
All the compressor wheels are coming from the same place... Find the cheapest one and go for it...:Thumbup:
BigBuilder was looking for a way to quiet down his early 99 turbo. When you get your new wheel in you might be a good neighbor and send him your stock one. I can't believe you would ever want to change back.
if you get a wheel make sure that you get it balanced. if you dont it could come apart at hi boost
Yeah joe some people on here are redneck shade tree mechanics that have our trucks held together with bubble gum and bailing twine. Then you have others of us who do things the right way.:pointlaugh :pointlaugh
The wheels are ballanced when you get them. If you look on the back side you will see a section that has been machined down. That is how they ballance them. The turbine wheel/shaft is ballanced and the compressor wheel is ballanced so when you put them together they are ballanced.
4
On my early 99 I've never experienced turbo surge. I've heard it on my Dad's 02 however.
i have not done it, but that sounds ok as long as the installer doesn't mash the screwdriver in the wheel and twist the **** out of it or something. plus they said it was padded with duct tape.
The ww did completely get rid of the turbo surge on my truck as well.
Discussion Starter #19
That is what I wanted to hear. I will be putting in a ww in about a week or two when I replace the CPS. I figured I would do it all at once.
I shoved a screwdriver when I did mine. It worked out great. About 25k later I pulled my turbo to replace it with a BB one... and there is absolutely no play in the turbo wheel!! I have not heard of anyone having a problem with their turbo after doing this either?? Well maybe not fess up to it!!
1 - 20 of 32 Posts
