1 - 14 of 14 Posts
TDG Mafia Member #45
i'm looking at getting a turbo house for my truck. what would be a good one. witch house should i replace? i know i should upgrade the complete turbo, but i'm on a super tite buget. i haul a tractor every know and then and i also haul my toyota when i go 4wheelin'. and i'm looking at a 30ft camper. i have 125hp injectors
Is your truck an auto or a manual trans. If it is an auto, then you have an hy35, I believe the manual still had the hx35. Anyways, an hy only has a 9cm exhaust housing, so going up to a 12 or 14 would help you out tremendously. I think a 16cm would be way too big for what you are trying to do. Htt sells some nice exhaust housings.
my truck a five speeds. i have an edge ez also. i' m think about going to a 14. will this boost power or will it stay the same. it doesn't matter to much to me, just as long as it keeps the truck cool when hauling something.
The 14 will make spool up a touch more laggy, but if you just delay your shift points you shouldn't have an issue. Ultimately it will keep it cooler on the top end as well.
B
I went with a 16cm non-wastegated. They are available new and used lots of places and are not real expensive. There is a fair amount more lag over the stock 12cm, but once you learn to drive it with the new housing it is not bad at all. I pull a g/n trailer a lot and the reduction in egt's is well worth the lag. I lost about 100* emtpy cruising down the Interstate and close to 200* while towing. Plus I went from a wastegated 39lbs of boost to a non-wastegated 40lbs of boost max. I was worried at first how much boost I would see, but it worked out perfect for where I want to be.
The 14cm or 16cm would either work, but you will have more gain with the 16cm. Just have to sacrafice a little lag off the line.
Yeah I wasn't sure about the 16cm just because of the lag factor. However I'm coming from an auto, so I would imagine that the lag is a lot worse, you guys can just hold your gear longer.
I am interested in upgrading housings but when I went to HTT's site they said none of there housings would work for an auto with an hy...what could i do?..get an hx and put it on my truck?
you could get an hx but then you're already spending money on a turbo and a housing, you might as well buy an upgraded turbo, like a 35/40 hybrid. Research it, I bet someone is making housing for hy's.
ok i talk to htturbo today. they said i should get the 14 or the 16. the 14 is $177 and the 16 is $155. my turbo spools up at around 1300 to 1400, where is a 16 going to spool up at.
also the adapter, do i have to have it or is it something i can fab myself.
B
What adapter are you referring to? With a 14 or 16 non-wastegated the only thing that changes is the downpipe will have to be moved 1" in towards the turbo to make up for not having the wastegated housing. I can't help you on the temp, because all trucks are different.
let restate this my trubo spools up at around 1300 to 1400 rpm. just a ball park number. where do you guys thank a 16cm would spool up at.
to use a non/wastegate housing you need to use the cast elbow off 94 to 99 hx35 turbo to hook to stock or aftermarket down pipe. the non/wastegate housing have a v-band clamp on the back like a 89 to 93 turbo. i just took off a HX35/40-14 n/wastegate to put on my HTT 66/14. i think i have part of the pipe you will need pm me if you need it. thanks
Discussion Starter #13
i ordered a 16cm housing, should be here friday. they wanted $109 for the cast elbow. you by the elbow from dodge for $58. i think i know were one is. the price is right a lot most free.
bigdodge aren't you guys making a intake?
yes we are. just put one on the green machine race truck before they went to texas for the dhra finals. they run a 9.90et. check it out on moparmax.com
1 - 14 of 14 Posts
