ok i am trying to remove the turbo to get to the egr cooler but the turbo is not moving...i have two bolts out from the front and one from the back the v clamp on the dp is off and the clamp on the y pipe is loose but not moving and oil line is off am i missing something or what thanks guys
finish getting the clamp off from the Y pipe and get it loose from the turbo... You need to lift up on the turbo then to get it off..
going from memory that should be it. it might need a bit of " persuasion" to get it off.
Discussion Starter · #4 ·
thanks guys i was able to get the clamp off after a little bit of rust breaker and got it out thanks
there are three bolts that hold the turbo down..one on the back side...take a look you can hardly see it
