Has anyone had or is having blow off flutter noise from the waste gate? My 6.7 has 23,000mi on it and I had a tranny update recently. Tranny was getting stuck in neutral between different gears. Had to let of the pedal then get back on it to get it to shift. I notice the flutter more often now. Going up a long hill and high gear. Low RPM. Is this normal or cause for concern? Turbo going bad or EGR just like the 6.0?
I've had mine in for turbo flutter and it does it all the time and I can get it to do it in all gears. No word from dealer yet.
Seems to be tied to RPM when I get 'between shifts' it lugs and flutters. I depress the pedal to shift and get into higher RPM and it doesn't do it.
I also call it turbo stall.
Sorry, no answer for you other than mine has been doing it for a while.
