are you limited to how sharp you can turn with a trailer with a weight distributing hitch?
reason i ask is i was turning around the other day and one of the tension bars flew out and the place it fits into the hitch was bent out(the little ball area.)
Gear jammin fool
Back when I pulled a bumper pull, if I was getting into manuveuring I would removed the bars(like backing in at the house). I'd stop up the street, remove the bars so I could back in easily without binding.
They have "give" for what I would call normal cornering, but if you get them too tight I think they could do just what happened to you.
I had the same type as you, just snapped into a small socket and had a little clip up top to hold them. Maybe the other design which slips up in a tube would be better? Or would they tear something else up?
Maybe it has to do with how tight you have them also? My one truck I would just use my arm to lift them to latch it as I just wanted to add some resistance to the bob/weave it used to get hitting bumps. My one ton I would use the cheater bar to pop it up.
i was just doing like a long u-turn and it popped. i was in a parking lot so there was no speed. they replaced it free of charge so thats a plus.
Gear jammin fool
Might have been a faulty set up? Too sloppy of fit? The catch pin on the top too loose?
Glad to hear they replaced it.
I have turned tight enough that the tipups marked the bumper with sway cams.
If the chains are a little short on the tipups they will move the brackets or pop the chains, if they are loaded a broken chain will often take out the retainer catch on the top of the hitch. Dragging a springbar down the highway usually makes it useless.
