All right guys this may be a silly question, but I haven't had a turn signal problem since I sold my '76 150 15 years ago. Lights and fuses are ok under the dash and the power box under the hood. Is there a relay somewhere? Surely no old style flasher like the '76 hidden somewhere? Any help would be appreciated.
rock removal technition
what year truck , obs has a flasher in the fuse panel.
I have had to replace the whole turn signal switch twice over the last 5 years, easy to do , just a little spendy.
Discussion Starter · #4 ·
Sorry, had to leave in a hurry yesterday. It is a 2000 F250.
shes smart!
I would have to say it is in the switch, Im not for sure about a relay your owners manual will show you if there is a relay i would check that first before replacing the switch.
MAFIA MEMBER 106
probably ur turn sig cam they break. do you not have right left or both front or rear and do you have brake lights? plus you can take a test light/volt meter and check @ your trailer plug conn @the rear of your truck the relay is under the hood near the main power dist box not sure witch one ck ur owners manual good luck steve
