Can you turn up the pump on 2002 7.3 psd? If so how?
no there is no "pump" to turn up. everything is electronic so if you want more power you have to buy a chip. the only thing you can do is shim the FPR.
Right...that was dumb.That shim trick on the regulator is done with a BB isn't it?
on the OBS yes, im not sure about how to do it on a SD.
Truck pullin' S.O.B.
How do you shim the FPR on an OBS?
on the side of the regulator there is a plug you pull, then inside there is a spring and a triangle looking thing. put the BB inside the triangle think put the spring back in. then reinstall the triangle thing and put the plug black on.
