was wondering how people have been attaching theirs and what risks there might be in doing this
TDG Mafia Member #21
I might have a pic of mine at home I can post. I will check tomorrow. The biggest danger is overpressuring the turbo and causing a bark that might mess up the shaft. You probably won't make enough pressure to worry the headgasket. I know I can't make that much pressure with my truck.
I appreciate it. would like some more boost it's only stock would just like 25-28lbs
If you turnbuckle the turbo without a boost fooler you will throw a code and the truck will defuel on you. I had this happen when I sent the comp off for some work. It is not fun.
I have a edge juice with att so I have one built in right?
Yes you do. Still working on the pic for you.
