what is the cheapest set of twins you can get, running 200hp sticks, mybe useing my stock turbo if i can find a kit and another turbos anyone have any ideas
source automotive has one that uses the stock turbo.
How much fab can you do yourself? building twins isn't too hard. I'd say put your stocker over an s400 or ht3b with a 38mm external gate on there and you should be good. If you upgrade your stock charger to a 60mm comp wheel that would be better too. If you want to buy a kit, look at source automotive, Relentless diesel, or Kendrick diesel. That should run you about 2800-3500 you could build them for about 1500-2000.
Sorry, but to me it kinda looks like this guy has a 7.3 and just posted in the wrong place? 355cc's is the equivalent of a 200hp injector in the HEUI world.....:poke:
Pretty sure, he sold that 7.3L and has an 01 dodge now, and just never edited the signature.
On a side note, 355cc injectors are worth 200hp? Thats good to know. I know almost nothing about fords, but may be helping my brother build his if he decides to hot rod it, and it is good to have comparison point.
