what is the proper way to check u-joint and your driveshaft to see if they are still good. 01 3/4ton:shrug:
mvwheeler02
if the driveshaft isnt bent and the joint ends are still good then it should be fine and for the u joints u are prolly better off just getting new ones there not that much to know for sure there good!
If you got a 2 piece you can put one hand on each one and move the shafts in opposite directions. If it's bad, you'll know. You really need to check alot of u-joints to get a feel for what's diffently bad and good.
Speaking of u-joints.............anyone got the whole listing of Dana part #'s?
