The Guy Mom Warned About
I'm going to be installing my SCT in a couple of days and I'll be using my Edge on the stock setting for gauges. So my question is, will I still be able to use the turbo timer and the other built in features of the edge?
Yes, you can. If you are running custom programs, let them know you are running the Edge Platinum even if it's turned off. The Edge is a piggy back device and stock isn't 100% stock.
Also, it's a good idea to unplug the Edge when you flash the PCM/TCM.
illadvised and dangerous
With the edge set to stock you will still have some edge feedback. I was doing the same thing at one time. I noticed less smoke and a 3rd to 5th flare in shifting... Side note I'm now having a issue with 3rd to 5th.
