Hello to all.
Yes please. I would like to see the Oasis results of this F350 I am analyzing. Thanks in advance for your time and help.
Paul.
VIN: 1FTWW33P77EA15515
Standard Claims List For Model Year 2007
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 15 7H06 120305 * FREON * C05 42 21737
AWS Claim Key: 1405401 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-NOV-2007 Doc #:139782A
Cust Comments: CUSTOMER STATES THE A C IS NOT COOLING PROPERLY
Tech Comments: PRESSURE TEST A C 15 200 AND TEMP WAS 50 TEMP AT CENTER VENT WAS 50. CHECKED FOR LEAK W ELECTRIC TESTER AND DID NOT SHOW ANY LEAKS. RECOVER FREON AND VACUUM AND RECHARGED UNIT TO 2.85 OZ. PRESSURE WAS 30 258 AND TEMP WAS 42.
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 21 7F11 110501 4C3Z 13K359 AAA L26 42 31902
AWS Claim Key: 2656270 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2008 Doc #:143420C
Cust Comments: CUSTOMER STATES THE STOP LIGHTS DO NOT WORK
Tech Comments: CHECK FUSES ALL OK CHECK POWER TO MUTIFUNCTION SWITCH OPEN IN MUTIFUNCTION SWITH OR BRAKE LIGH T CIRCUIT REPALCE MULTIFUNCTION SWITCH
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 21 7C04 180201 5C3Z 13350 AA L26 42 31902
AWS Claim Key: 2656269 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2008 Doc #:143420A
Cust Comments: CUSTOMER STATES THE BLINKERS DO NOT WORK. THE FUSES ARE BURNING AS SOON AS THEY ARE REPLACED. THE STOP LIGHTS DO NOT WORK.
Tech Comments: NO FUSE BLOWN BLINKING INOP OPEN IN BLINKER REL AY REPALCE RELAY NO BRAKE LIGHTS THROUGH MUTLFU NCTION SWITCH REPALE SWITCH OPEN CIRCUIT
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 26 2E01 03XXXX * 9B246 * D02 42 41252
AWS Claim Key: 3558332 Trx Code: E72 Labor Hrs: 10.9
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2008 Doc #:146097A
Cust Comments: CUSTOMER STATES THE VEHICLE TURNED OFF WHILE DRIVING. CRANKS AND WONT START.
Tech Comments: USE IDS TO RUN EECTEST P2291 LOW ICP 295 PSI CJ HECK PER TSB 081816 AIR TEST SHOWING LEAK AT ST C FITTING R AND R HIGH PRESSURE PUMP TO REPLACE STC FITTING CLEAR CODES ROADTEST
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 26 2A01 031202 6C3Z 6C640 A D42 63 41252
AWS Claim Key: 3558333 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2008 Doc #:146097C
Cust Comments: CUSTOMER STATES THERE IS NO POWER AND AN AIR NOISE FROM THE ENGINE AREA.
Tech Comments: UPPER CAC HOSE HOTSIDE BLOWN ON TEST DRIVE REPA LE HOSE CHECK BOOST 23 PSI
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 26 1A01 030102 6C3Z 6049 AA E68 42 41575
AWS Claim Key: 3714594 Trx Code: E72 Labor Hrs: 19.6
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-OCT-2008 Doc #:146335A
Cust Comments: CUSTOMER STATES THERE IS DIESEL LEAKING INTO THE COOLING SYSTEM.
Tech Comments: ASK HOTLINE FOR DIRECTION ADVISED TO REMOVE ALL INJ PRESSURE COOLING SYSTEM APPLY SOAPY SOLUTION TO CUPS TO TRY AND NARROW DOWN SOURCE OF LEAK CONNECTBLOCK HEATER NO LEAKS NOTED ADVISED TO REPLACE BO TH HEADS REQUEST PRIOR APPROVAL FOR HEADS REPALCE LEFT AND RIGHT HEADS M TIME TO REMOVE INJ FOR LEAKTESTING
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 32 1B03 030204 * 6A642 * L87 55 50238
AWS Claim Key: 4461152 Trx Code: E72 Labor Hrs: 9.7
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-APR-2009 Doc #:149090A
Cust Comments: CUSTOMER STATES THE VEHICLE IS LOOSING COOLANT. THERE IS WHITE SMOKE COMING OUT OF THE EXHAUST.
Tech Comments: 50238 ENGINE HYDO LOCKED GLOW PLUG RIGHT SIDE TO CLEAR INITIAL VACCUM CHECKED REMOVED EGR COOLER TO TEST EGR COOLER LEAKING REQUSDT PREIOR APPROVAL FOR EGR COOLER REPLACE EGR OIL COOLER KIT CHANGE OIL AND FILTER FLUSH COOLING SYSTEM TEST DRIVE EOT & ECT 10 DEG APART COOLING FAN OK BOOST OK AT 24 PSI
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 32 2H01 03XXXX * 6K682 * N11 42 50536
AWS Claim Key: 4498590 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 04406 - * Name: BOWDEN FORD LINCOLN MERCURY CO. Ph: 361-6649541 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-APR-2009 Doc #:149251A
Cust Comments: CUSTOMER STATES THE TURBO IS MAKING A LOUD NOISE..TURBO HOSE KEEPS ON POPPING OFF.
Tech Comments: 50536 USE IDS TO CHECK TURBO OPERATION PER TSB 081613 REMOVE TURBO TO INSPECT CORROSION ON CHRA REPALCE CHRA AND CLEAN VANES REINSTALL TURBO AND ROADTEST
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 38 1B03 030204 3C3Z 6A642 CA L65 42 60740
AWS Claim Key: 5444992 Trx Code: E72 Labor Hrs: 12.7
Dlr Cd-Sub Cd: 04161 - * Name: EDDIE YAKLIN FORD LINCOLN MERCURY, LTD. Ph: 361-5922661 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:30-OCT-2009 Doc #:168609A
Cust Comments: CUSTOMER STATES THERE IS OIL IN THE COOLANT SYSTEM
Tech Comments: VERIFIED THAT VEHICLE HAD OIL IN COOLANT. RAN OASIS AND FOUND TSB 9 18 12. FOLLOWED PROCEDURES AND R&R OIL COOLER PER WSM, TESTED EGR COOLER OFF VEHICLE AND FAILED. R&R EGR COOLER, WHILE TURBO WAS OFF TURBO HAD BAKED ON OIL AND CAC AND INTAKE MANIFOLD. CONTACTED HOTLINE AND WAS TOLD THAT IS WAS DUE TO OIL IN COOLANT. M TIME TO CLEAN CAC, CAC TUBES, TURBO, INTAKE MANIFOLD. PUT BACK
1FTWW33P77EA15515 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 09-JUN-2006 18-SEP-2006 152099 USA 50 2E03 030402 4C3Z 9E527 BRM D42 42 92404
AWS Claim Key: 6411361 Trx Code: S07 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 04584 - * Name: CHAMPION FORD Ph: 361-9946200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2010 Doc #:493528A
Cust Comments: CUSTOMER STATES VEHIOCLE RUNS ROUGH ON COLD START
Tech Comments: VERIFIED ENGINE RUNNING ROUGH ON COLD START TIL WARM.PERFORMED TESTS PER DIESEL ENGINE PERFORMANCE DIAG WORKSHEET.PERFORMED VISUAL INSPECTION.OK. CHECKED FOR CLEAN FUEL.OK.CHECKED OIL LEVEL.OK.EEC TESTED KOEO P1111 KOER P1111 KOEC P0284.PERFORMED INJECTOR ELECTRICAL TEST.PASSED.PERFORMED PINPOINT TEST P PER PCED.PERFORMED POWER BALANCE ON COLD START.FOUND CYLS 4,7,& 8 DROPPED TO 60
Many thanks for taking time out to provide me with this OASIS information. It is priceless for my decision making. Thanks again, I really appreciate it.
