1 - 10 of 10 Posts
A couple months back I had a BD light that used to flicker (very rarely) when i had low fuel pressure, so i bought a raptor pump.
Had an erratic idle when warm, and blew white smoke when first start up.
Changed to a different fuel station put in injector cleaner and all problems went away. Until NOW
My truck has 211K miles on it, VP was replaced at 145K miles. I pulled out of work, truck still cold, got on it, truck shut off when i let off at 40 mph. It just cranks over now. I have 17 psi when the fuel pump (Raptor pump) kicks on, power and ground going in the injection pump, new fuel filter, and no codes. What else can I test to verify that it could be the Injection pump?
Let it rip tator chip!
thats the same way it did to daddy's did didnt throw a code or nothin dead peddle and white smoke like crazy but i dont know tho
i was started to leave the farm and pure white i couldve swore up and down it couldve blocked an intersection but s*** happens tho
Last time I had to do that was because the clutch was shot.
it was weird with mine bc roughly the same time period the pump and the clutch went out at the same time
1 - 10 of 10 Posts
