1 - 11 of 11 Posts
A buddy of mine thinks he can rebuild a VP for around $100.LOL All he needs is instructions. Does anyone know where I can get a rebuild manual.
Not possible... LOL
Here is a post from a guy that did it
http://www.dieseltruckresource.com/dev/vp44-rebuilding-t111329.html
WHOO HOO! Anybody want to drive my "New" truck!!!!
Happy to report that the pump is back together and running like a sewing machine. Much more power and no Dead Pedal! I have only about 10 miles on it so I will keep you advised if anything changes.
See my note above in post #11 that outlines the major problem. I think that is the lack of power and fuel economy issue. It may also be the dead pedal issue as well.
Now, I would not say it went totally without a hitch and the problems were self inflicted. If you are going to do it yur self, I will recommed a few things:
1, do not disturb the bronze ring on the main shaft. It is the reluctor for the timing pickup and controls the timing of the pump. I removed it and had to time it by trial and error.
2, Pay attention to the orientation of the parts as it is possible to get it 180 deg out of sync which I did the first time. There are no marks for alignment of the parts, so mark them upon disassembly to ensure proper re-assembly.
Hardest part of working on it are those darn tamper resistant torx screws and the fact that there are no manuals that I could find.
Parts: Bosch gasket kit (all orings) part# DGK138 from USDiesel in Ft. Worth TX (817) 485-6422 Mr. Brad Glenn. $37.88
If you have above average mechanical aptitude and a want to save $1500, then you can try this yourself. If i get time, I may put together a proceedure or you can e-mail me direct for my opinion and assistance. [email protected]
This may not fix a really screwed up pump, but it fixed mine. By the way, this was the original pump in my 2001 3500 with 195,000 miles and it was not worn out.
Let it rip tator chip!
I wouldnt recommend it, just because when you go with reman. parts or a reman pump.Their just recondition parts like the cam,delivery valves and etc. The only parts that are new is the electrical. My 2 cents is, if his pump went bad i would go with a bigger pump. Reason 1 is, if he messed up rebuilding it and the truck dont run right, your spendin the extra time and money to take it out and try to diagnose the problem Reason 2 Everyone ive talked to that has a reman. pump or rebuild kit. Their not happy with it. Reason 3 i wouldnt think theres a warrenty with the kit
GotRamCumm'
VP-44 Electronics Repair
Help. Trying to do FastFreddie's VP-44 circuit board repair. Struggled with one screw on ribbon cable connector. That bugger was tight. Long story short after 2 hours of finessing the screw the torx driver wrung off in the screw. Two more hours trying to get the piece of the driver out of the screw. Not much chance now but to drill the head off of the screw. Does anyone know the size/thread count of the ribbon cable connector attaching screws. I'm down as this is my only vehicle and I'm a $45 (one way) to the nearest store with fasteners. Any help would be appreciated.
Thx
GotRamCumm'
VP44 Electronics Rework Source
Found a source for the VP44 Electronics Pack??
I have found a source in Poland that will rebuild the Electronics for $158 Euros. Problem is I don't have the time as this is my only vehicle. The link to the electronics rebuilder is: http://www.vp44diesel.de/en/price-list . Appears they do a huge worldwide business rebuilding diesel pumps and drive computers for all types of oem vehicles.
GotRamCumm'
There is a reason shops pay 400 K for test benches to work on VP44's only.
Good luck
Thank you for your input and I understand your point. I've heard mixed opinions on the setup of the electronics and the greatest need for the test stand is the timing issues that are primarily mechanical. The electronic timing could easily be addressed by having the stats and a good laptop with the appropriate programming. I worked for Bosch in the 90's and was a good friend that designed the current model test stand and the computer end of it was very basic.
At the same time, being in business myself I would be willing to bet the primary reason that shops buy the test stand is profit. That is not to say that the test stand is not required but for the electronics the requirement is a little vague.
While my truck is down I have ordered a VP44 but now I'm just playing with this electronics project.
GotRamCumm'
Well, looks like I'm going to give up on trying to save this old VP44 core I have available. I had hoped to fix it up and put it in my Ram but it is just too much effort. I had hoped to re-solder a few crystallized an probably resulted in a bad connection. That's why the guy gave it to me. So I'll put it aside and maybe work on it when a few slow days come along.
In the meantime I'll pull the one off of my truck and exchange it for a reman so I can get back on the road. The whole thing of rebuilding the spare I had was probably just a bad dream.
Once in a while someone will burn up the electronics, this was more common with FedEx and UPS trucks, if they catch the problem early, then a brain will fix the issues. But that does not happen very often.
Good luck, you might be able to do it.
If I was going to try just taking it apart and replacing the worn parts I would get the Chinese parts so if it does not work, you just have a third the money in it.
GotRamCumm'
Found and honest electronic module repair service
I found an organization , EGR Solutions, LLC. that does module repairs. They are located in the U.S. in Georgia.
I can't speak more highly of them. I worked with a gentleman named Emanual. He assured me that they would analyze the module and if it could be repaired it would cost no more than $299 depending on hours taken and probably significantly less..
He kept in touch with me for over the period of a week finally advising that there were "hair" fine, nearly microscopic, wires that had corroded and he knew of no one that could do that kind of repair.
He indicated that the typical VP-44 repair is to the small (but not microsocpic) gauge wires that are repairable and while they repaired a few of those for me they then in found in testing there was still a problem ultimately found to be the really fine wires to the microprocesor. It is very possible I created the problem myself by looking into the module.
The bottom line was that they could not repair mine but, even though they spent hours, diagnosing my module they did not charge me for their time. They didn't even charge me for priority shipping back to me.
I can't speak highly enough of this organization. Emanual can be reached by email at [email protected].
Now I move on to getting a reman VP44. I genuinely feel I took the right path rather than jumping straight to a reman VP44 as this was my second failure in 225k miles and both times it was felt to be the module and not the pump.
1 - 11 of 11 Posts
