Will it hurt to run it unplugged?
BTW unplug waste gate because of lack of boost, boost is now up to normall to 22psi.
What NAPA filter do you use for the DIY intake?
Napa part # 6637
Wix part # 46637
2001 F350 4x4 crew cab short bed 7.3L auto 6" w/ 42" swampers F550 D60
Dynatrac combo kit K&N 80 horse chip 4'' turbo back fuel tank mods HPX
Cummin' get ya some!
i was wondering the same thing.....about the wastegate
Unplugging the wastegate could allow the turbo to overspeed and damage it. It could also create a lot of backpressure with that small stock turbine housing. So yes, it could hurt something. That being said, I've run with it unplugged and so have alot of others. Their is a possibility for damage though so be aware.
Thank you
Thanks alot
Thanks alot
TDG Member Since 2004?
Running without the wastegate control won't help much on a stock truck. If you have a boost gauge, don't push the stock turbo over 25# of boost.
