'Ol Builder guy
I might be starting a project truck. It's a Ford F-series (F-800) with a 5.9L and the trans has been removed. It was a stick. If I want to import an Allison into it, what allison would it have been? A MT653? Not sure if that year 5.9 was electronic.
What are my other options with other Allisons? Truck will be used for grunt farm work & snowplowing, nothing over 55 MPH. Sorry don't have rear gearing (yet).
Super Moderator
First likelihood is an AT545, second place would be the MT643. The electronic version (ISB) started in 97-98-ish.
Duke ----What has the truck done in its previous life ? Is there any indication if it had a reducing ring from flywheel housing to transmission,say a SAE 2 to SAE 3 would indicate it was an AT 545/542 ,[not good for dump truck application].MT 643/653 is the minimum you should consider with lockup converter .Is the flexplate still on the engine ? What is the bolt circle to fasten the flexplate to the converter ? What pattern does the shift quadrent show ? Electronic controlled transmissions were out by the mid '90s ,so that doubles the possibilities . If you'd care to,call 330-467-9357 .
Mechanical governed engines used a TPS [throttle position]sensor with electronic engines . Also,an F800 GVW is higher than you'd normally see a AT 545 in . Just reread your post and noticed it was a manual trans originally ,so disregard much of my banter .
You need to know what the engine CPL is and then I would call Detroit, Alison and ask them. Lots of trucks ran the 545, the 653 is a better choice, The 654 has a bit to much Torque to get any RPM out of a 5.9. That is the worst thing about a 5.9 of lower torque settings they end up with to low a stall speed.
'Ol Builder guy
Despite my disliking, I could turn up the 5.9L a bit if it's a 190 or 210 and keep a pyro gauge right on the dash in front of me. I think if I can get it up to 250HP, it would live a long life and be froggy enough for a MT allison. Should have a P-pump and be easy with a 4" exhaust
Truck will have aluminum dumping flatbed and gooseneck hitch to pull my 7040 and attachments around. I really wanted a '06+ GM 3500HD 4WD, but just can't swing it $$ right now.
I'm gettin way ahead of myself, more thinking out loud. I have to get a shipping quote and do a budget to see if I can even do this. I might end up doing a 5 speed 2 speed rear with 4WD lockout if the Ally becomes too spendy and just keep trying to get an Ally in my 4800.
Super Moderator
The AT545 would be the least costly and most common trans behind that engine, the MT643 would likely have been an option.
The MT643 is only a "better" choice if you have easy access to one at a modest cost.
In either event, there are many parts to be sourced for a conversion, I've done this three times but only with access to parts books or doner units.
