I first got my truck less than a year ago. Soon after it started lossing all power and didnt wanna go in the middle of driving somewhere. I soon put the fass system and a new injection pump in problem solved.the to me it sometimes drags second out and doesnt wanna shift. I have never gotten above 13 mpg.anyway I did everything to get feul mileage up to no avail nothing worked Finally I added a new tranny.I still have the shift problem plus a surge ehen putting through parking lots and when hammering on the pedal,also last week I filled up and got on the gas pulling out the truck shut down and I had to bleed the injectors to get it to run. it also jumps in and out of lockup between 45-55. Tried resseting the apps as described on this site. Took away the lockup problem but a week later and its back please help
TDG Mafia Member #21
Resetting the apps is just a temporary fix sometimes. You also need to clean your grounds real well and shield the alternator charge wire. If it still does it your next step would be to get a noise filter from DTT.As far as the other tranny issues go, there are a few tranny builders on here that are mentioned all the time. That is for a reason. They have a proven track record with putting a trans together that will hold what these trucks are putting out. It sounds to me like the torque convertor is slipping on you. That is the surging you are feeling while you are hammering the throttle(the power is to much for it to hold) the surge while putting through a parking lot is from the line pressure being low because of the upgrades and the pedal hardly being pushed. This creates the same situation. Not enough pressure in the tc and you get the surge. This is my opinion and not a diagnosis. I had similar issues though before I put in my tranny.
As far as bleeding the injectors and the stalling, start at the tank and check every fitting and inch of hose and see if you can find an air leak. They are a real PITA to find sometimes. I have been chasing one for more than a week now and still don't have it taken care of. If that doesn't help we can go into more detail and find some other possibilities.
what is the best tranny builder for me.Every day driver but still want an awesome truck.
B
Several to choose from. I personally would go wih Goerend or Suncoast. There is also ATS, DTT, and some others.
My signature says who I think is the best. GB all the way for me.
