1 - 10 of 10 Posts
I have the turbo off for cleaning and plan on doing the ccv re rout mod is there any thing else that I should do while I am in there with the turbo off the truck thanks
anybody? I will have the turbo off until I get a new one so I have time :bang so any advice or sugestions will be great thanks
PitBullPowerStroker
EGR delete comes to mind since your in that far. Or at least remove and clean the EGR valve.
Just did it on my 04 finally and should have done it sooner.
Check for schaffed wiring too
Reactions: vcassens
thanks for the ideas I just checked it for chafing about 3 months ago and fixed 3 spots I was saving the egr delete for when I do the studs but might look more into it now that I have the time
hit all the solder spots inside the FICM
If I do anything with the egr I will probably weld the cooler up for now
i believe there is a large oil drain tube that helps... my mechanic installed that when my turbo was off.
how can I tell if I have the lager drain tube on the truck?
Reactions: vcassens
1 - 10 of 10 Posts
