Robts or EB.bldr are the guys to talk to on the CR on here.
From my understanding the '06 has a bit more involved for wiring purposes. '04.5's can be desirable as they still use the mechanical TPS to pedal cable. This can have it's advantages for trottle peddle selection as well as CC operation....i think id like to keep the same year engine 06 obviously but whats all involved...
Some of those things will be controlled by the Ford ECM. If/when you get an engine it would be a double bonus if you were to come out with as much of the wiring off the donar as possible. The Cummins will have it's own OBDII....how are you guys tying into the truck ie getting the tach, speedo, etc to all work with the cummins, how are you getting the obd port to work with the smarty and things like that?..
Aftermarket. The Ford IC has plastic end tanks that WILL blow up. Interco or Banks....whats being done for intercooling, stock ford ic? custom?
my goal would be 06 c.r. with a reliable 500-600whp 1000-1200tq what all do i need to do?
HP rating will be the same in this or a Fiat product. So working with HPnums has plenty of options. I would be researching injectors, turbo, and CP3 pumps to find a good combo that will work for you.
Turbonetics......Must of had tires on the mind.:damnit...Spearco...
yup! it will also hold up better. i wouldnt trust a built 5r110 with a stand alone controller behind a 600hp cummins.Dont waste your money on a 5r110. You will need a pcs controller, fly wheel and adaptor. A built dodge 48re is alot better. No pcs or stand alone transcontroller, custom fly wheel or adaptor. Its alot easier to do and tune
