I have a good hx35 and found a couple hx40's with some good parts and some bad. What do I need from each turbo to make a good hybrid?
One of the hx40's comp wheel is bad (see pic) could I just bolt this 40 on and have no worries?
You need the comp side of the 40. Also some machining mods are required to get it work with your ex. housing. I don't remember what specifically has to be done, but if you call htt they can help you out.
You could just bolt a 40 up, but with the amount of fuel you have, it will be a ***** to spool up. My friend has a similar set up as you do, but with stage 3 nozzles and that thing is a pig around town with the pdr hotrod 40 on there.
